Disco I ECU question
Old Jan 10, 2013 | 12:10 PM
bushpilot's Avatar
Default Disco I ECU question
Hi - does anyone know if all the ECU's were the same for a 97' Disco I? Still trying to workout the high idle and I believe my next resort will be to take the IAC and ECU as a pair from a Pull a part doner. Just trying to get an idea in advance if all the ECU's were the same before I start pulling. Thanks
Old Jan 10, 2013 | 01:47 PM
jafir's Avatar
I don't think so. I think some will be advanced evap and some will not.
Old Jan 10, 2013 | 04:17 PM
And I belive I have done exactly that - got the ECU/IACV from boneyard, 1997 truck runs great, can't fix evap codes because it is looking for the other system. My PO had already disabled the CEL, and I don't live in a county with infections (errr... inspectons). Original truck had sky high idle and would not relearn even a brand new IACV. So if you have a choice, go with truck that has matching emmission canister (round or rectangle).
Old Jan 11, 2013 | 06:51 AM
ihscouts's Avatar
An early evap equipped ECU motor runs smoother with a later AEL ECU. The firmware for the A/F trim was updated. Might or might not set a CEL for tank purge, most probably not as was the case with a good friend and myself who did just this.
Paul Grant
Aug 10, 2014 12:29 PM
MarvelVT
Dec 26, 2009 10:29 PM
bigugly82
Sep 6, 2007 09:01 AM
