Disco1 3.9 Stalling issues
Old Oct 13, 2010 | 07:25 AM
joverrover's Avatar
Default Disco1 3.9 Stalling issues
I have a 94 D1 and it has been stalling at stops and when slowly turning around corners. It immediately starts up again, surprisingly its when my girlfriend drives it. Thanks
Old Oct 13, 2010 | 07:53 AM
okdiscoguy's Avatar
I would suggest a good throttle body cleaning. Take out the Idle air control valve and make sure it is clean. Do not move the plunger, just spray it. Pay the most attention to the hole it sits in. Pretty sure there is a write up for cleaning in the tech section.
Keep in mind that you may want to change your oil after the cleaning as some of the cleaner and gunk will make it's way in. This is a good time to do a Seafoam induction cleaning as well...
Old Oct 13, 2010 | 07:54 AM
XCELLER8's Avatar
without any further info than what you've given us, other than changing girlfriends (which may not be an option) it sounds like it's time for a good tune up and throttle body cleaning.....check out the maintenance section for the reccommended service items. let us know how it goes
Old Oct 13, 2010 | 08:01 AM
okdiscoguy's Avatar
Oh, and I was assuming it is an auto. The GF may not be pushing the clutch in all the way if it is a standard... (haha)
Old Oct 14, 2010 | 12:40 PM
joverrover's Avatar
Thanks for the advice, I ll Let you know how it goes.
Old Oct 15, 2010 | 01:25 PM
joverrover's Avatar
I am not quite sure where the idle air control valve is.
Old Oct 15, 2010 | 06:32 PM
okdiscoguy's Avatar
Download the Rave manual in my signature. It is free.
Don't start pulling stuff until you know what you are doing.
start with this.. https://landroverforums.com/forum/sh...ad.php?t=19664
thearmlesswonder
Dec 18, 2014 02:58 PM
Timebus
Feb 17, 2011 10:10 AM
nomad64
Jul 27, 2006 09:50 PM
taylorbob1
Mar 21, 2006 12:53 PM
englishboyonice
Aug 5, 2005 03:34 AM
