To DiscoMike and other experts.
Old Jun 19, 2014 | 10:19 AM
MonteroMan's Avatar
Default Let's see...
Originally Posted by 96 rover
A 95 disco by the spider bypass plug and take the alarm out of the loop. They sale the by pass at rovers north I have one and use it when I work on 95 and 94 models. The spider is behind the radio you will have to remove the bezel to get to it.
Thank you, the vehicle has been standing now for 5 days and nothing brings on a spark - I'll go in there and see, but I am not sure I know what a "spider bypass plug" is, will look for something resembling a spider...
Still working my away around American terminology Do I have to buy a "spider bypass plug"
Old Jun 19, 2014 | 10:52 AM
96 rover's Avatar
Land Rover Anorak Technical Discovery I
Check this out it will explain it has part numbers also. And yes you have to buy it its cheap start there and see what you get you will have to do a computer reset also have you looked under the passenger seat to see what codes are showing on the obd1 read out.
Old Jun 19, 2014 | 11:25 AM
fishEH's Avatar
Is this a NAS D1?
If so, some very wise people would probably disagree on the Spider.
https://landroverforums.com/forum/di...d-story-66257/
Old Jun 19, 2014 | 11:31 AM
MonteroMan's Avatar
Default Ecm
Thanks, I really appreciate your inputs.
If you have time to read back on the history, I only twice had temporary readings on the display after having disconnected and reconnected the battery negative, and both times 02 (zero two?) showed. Other than that there has never been any light or indication of power. The history will show that after having fixed ignition components she would start and run perfectly for about a week and then out of the blue refuses to start.
Thanks, for the link, I am opening that now.
A.
Old Jun 19, 2014 | 11:34 AM
MonteroMan's Avatar
Default Al these unknown abbreviations...
Originally Posted by fishEH
Is this a NAS D1?
Thank you Fish, if only I know what NAS refers to I may say yay or nay...
Old Jun 19, 2014 | 11:45 AM
MonteroMan's Avatar
Default Nas
North Amrican Specifications. I would not know whether this 95 is or is not.
Old Jun 19, 2014 | 12:15 PM
MonteroMan's Avatar
Default NAS or not..
All I can see is that "This vehicle conforms to US EPA regulations for 1995 model", so whether that refers to NAS or not I do not know.
Old Jun 19, 2014 | 12:16 PM
fishEH's Avatar
Where is the truck now? If it was originally sold in North America then its probably a pretty safe bet its a NAS truck.
Old Jun 19, 2014 | 12:17 PM
fishEH's Avatar
Then yes its a NAS truck and should not have a Spyder.
Old Jun 19, 2014 | 12:29 PM
MonteroMan's Avatar
Thanks, Fish, I am in Craig, Colorado.
I checked the microfiche components diagram in that link you sent me and am trying to locate them all. Is that #1 component the Electronic Control Unit under the front pasenger seat?
I do not have the remote entry (FOB?) but have been locking and unlocking the vehicle with the key.
You'll see that the starting problem was intermittent and each time I replaced ignition components it disappeared for a week or so. Now the starter just turns the engine briskly but no start.
If I knew how to bypass the immobilizer I may (I hope) get it started. A little under pressure to get it going as it is my only transport.
