Discovery 1 indicator dashlight flashes once with every switch trigger
Old Jun 6, 2022 | 08:48 PM
eames's Avatar
Default Discovery 1 indicator dashlight flashes once with every switch trigger
Hi all hoping for some help troubleshooting a electrical problem.
My indicator dashlight will flash once with just about any switch trigger. For example, pressing the brake, turning the headlights on, turning the airconditioner on etc. will all see the indicator dashlight flash once. I'm stumped!
The other issue which I suspect is related, is my trailer light flashes with the indicator despite there being no trailer attached.
So far, I've cleaned up the battery ground and the two grounds above the rear tail lights but that's seen no success.
Here's a video link:
Open to any ideas!
Cheers!
Old Jun 10, 2022 | 02:29 PM
aemnky606's Avatar
The trailer light will flash one when you first turn on you turn signals but only once. I would take a look at your trailer connector to see if it has been damaged or has bad corrosion. I had a 4 way converter fail on me and the trailer light would come on and stay on any time I used my blinker.
Mountain Goat
Jan 12, 2011 03:07 PM
xrundelek
Jan 11, 2011 08:32 PM
Classic89
Nov 1, 2010 08:40 PM
ayteale
Nov 10, 2008 10:47 AM
racdisco
Feb 10, 2005 04:37 AM
