Discovery 1 U Joints
Old Jul 2, 2010 | 06:29 AM
Clunker's Avatar
Default Discovery 1 U Joints
Should I change my U joints periodically as a maintenance move? I have not had them changed in 100,000 miles. How can tell when they are bad? I thought I had checked them properly in my 2000 Range Rover and they seemed fine. I went on a 500 mile trip and started hearing a sound coming from the drive train and within that distance one snapped and beat the under carriage all to hell, including the transmission pan. I don't want that to happen again.
Thanks.
Old Jul 2, 2010 | 09:36 AM
discomedic4's Avatar
Are you having any symptoms such as clunking or play in the driveshaft? have you been greasing them at the correct intervals? I had one go bad so I rebuilt both the front and rear driveshafts just to be on the safe side and that way I knew when they were done, how they were done, and I could guarantee that from here on out they are serviced every oil change. Just my 2 cents.
Old Jul 2, 2010 | 09:50 AM
They need to be lubed at least twice a year, if they haven't been and you have a few extra $$$'s then I would say yes.
Old Jul 2, 2010 | 10:37 AM
AK Rover's Avatar
Changing out u-joints is cheap insurance from what could be a serious problem. I tried to grease my u-joints at every oil change but it didn't always happen but I did get them greased 3-4 times per year.
Old Jul 2, 2010 | 07:03 PM
Go ahead and change them and they will last another 100k.
Like AK said, cheap insurance.
Old Jul 2, 2010 | 09:25 PM
Danny Lee 97 Disco's Avatar
That's the best way to handle it.
Old Jul 4, 2010 | 07:04 PM
antichrist's Avatar
If you can grease them and get new grease to come from around all 4 seals on each u-joint, then grease them but still replace them before long.
If you can't get new grease to come from around all 4 seals, then replace them ASAP.
Old Jul 6, 2010 | 08:55 AM
Clunker's Avatar
Thanks. I'm on it!
jimvw57
Apr 29, 2015 02:17 PM
IMurray21
Oct 27, 2008 08:38 PM
Phototone
Apr 24, 2008 05:15 PM
dpeek
Sep 4, 2006 11:11 AM
klunkerchuncker
Jan 11, 2006 04:33 PM
