Discovery 1 Wierd oil leak on motor mount
Old Jan 6, 2018 | 06:40 PM
OverRover's Avatar
Glad you got it sorted without too many tears!
IIRC the O ring you need is metric.
Old Jan 6, 2018 | 06:57 PM
number9's Avatar
Originally Posted by Crunkgringo
I replaced that o-ring with what I had..
Originally Posted by old gold
Thanks for the feedback!
I had referenced the attached picture which showed a valve on both sides.
i will pick up a package of (25) 19 mm x 1.5 mm Viton O-rings from McMaster Carr (PN 9263K852).
I'll have 23 extra if anyone needs them.
Fyi, should be the size you're looking for.
Old Jan 7, 2018 | 01:42 PM
Crunkgringo's Avatar
Originally Posted by number9
That was a great idea to monitor with your gopro. Now I can see the benefits of one in my future. Easy to justify the time to learn the OS and using it as a tool. Thanks.
I couldn't think of any other way to catch a high pressure oil leak. I was just concerned that I might lose the camera. It did hit the oil filter but stayed put on smooth back-road highway. I confirmed today driving it about 100 miles that the problem is solved. There is no more oil leaking on the cat or pooling on the diff. I do have a rear main leak. Bumping up that oil pressure with the main and rod bearing replacement sure put everything to the test.
Thanks for the o-ring info! I will get some to have on standby.
tre soli
Jun 14, 2014 06:06 PM
khuds308
May 13, 2013 09:48 PM
vandev
Apr 4, 2010 08:36 PM
rickm
Jul 31, 2009 09:26 AM
Doral300sc
Feb 25, 2006 11:32 PM
