Discovery 1 wont start after it got wet
Old Dec 19, 2011 | 10:38 PM
deer4011's Avatar
Default Discovery 1 wont start after it got wet
On sunday i went offroading. i went through a mud hole pulled out to wait on a friend and it just died on me. its a 1999 discovery series 1. when i try to start it theres a clicking noise by the passanger side footwell and the injectors click but it wont turn over. i dont hear the fuel pump prime either and theres no pressure at the rail. but if i shift into neutral it will turn over but no start. i cant figure out whats wrong i reset the inertia switch and all my fuses are good.
Old Dec 20, 2011 | 09:24 AM
grandkodiak's Avatar
How deep did you go, how long was it in the water, and how long did it run once you where out before it stalled out on you?
check make sure the grounds and connectors for mud/water/crap contamination and clean em up as necessary. id pull open every harness i could get my hands on and clean em up and reseat, if not dirty mayby somethin just pulled loose.
any codes/dash lights come on? maybe crank po. sensor harness etc?
Old Dec 20, 2011 | 01:49 PM
deer4011's Avatar
The puddle was probably six inches deep at most it wasn't in for too long and it ran for about thirty seconds after I got out. Where are the grounds I'll check those.
Old Dec 20, 2011 | 02:51 PM
Did you get water on your ECU, if so you'll need to remove and dry it out.
disconic
Jun 4, 2016 02:57 AM
Josh.0
Mar 21, 2012 02:17 AM
gustav23
Dec 15, 2011 01:12 PM
brian891
Apr 4, 2010 09:11 AM
NWRover750
May 24, 2008 01:08 PM
