Discovery 1993
Old Oct 31, 2021 | 08:10 AM
Anthea's Avatar
5th Gear
Default Discovery 1993
Good day,
My father in-law has a problem with his Land Rover Discovery 1993. The car starts intermittently. It will start up and he drives it then after stopping after a few stops it won't start again then he will rest it over night and when he tries again the next day it will start. When you put the ignition on the fuel pump runs, there is spark, but it doesn't start, it just swings. The fuel pump relay and fuel filter was changed. Can you advise what this is?
Many thanks
Anthea
Old Oct 31, 2021 | 10:16 AM
disco96sd's Avatar
a likely culprit is the Crank-Position-Sensor
Old Oct 31, 2021 | 10:24 AM
The Deputy's Avatar
Check fuel pressure.
l'll move this to the Dl section for better results and help.
Old Oct 31, 2021 | 08:51 PM
XCELLER8's Avatar
the '93 should have the 14CUX fuel injection system, thus no crank sensor.......
1. check fuel pressure at the fitting on the fuel rail >>should be between 30 and 35 psi
2. you may see spark, but it may not be "good " spark........>>get a cheap in-line spark checker and check for a good spark at the plug cap(s)
3. you may have to dive into the ignition system further >> distributor cap & rotor, amplifier module , coil...a weak coil will produce visible spark , but not be sufficient to run the vehicle
4. what condition is the battery in ??
let us know what you find :0)
Old Oct 31, 2021 | 11:22 PM
Shiftonthefly1's Avatar
Failing Ign module.
Old Nov 1, 2021 | 02:55 AM
Anthea's Avatar
5th Gear
Thank you for all your assistants, i will relay the messages over and get back to you.
Old Nov 1, 2021 | 10:00 AM
FatMcNasty's Avatar
Just fixed my 95, this was the issue. also had a overheated wire from the amp to the coil.
Old Nov 3, 2021 | 10:43 AM
Anthea's Avatar
5th Gear
Default Discovery '93
Hi all
Firstly I want to thank everyone for your input and help with my thread.
My husband has managed to fix the problem.
It was the injector relay and has now been replaced.
Many thanks
Old Nov 3, 2021 | 11:35 AM
disco96sd's Avatar
do you mean fuel pump relay ? - not aware of any part on a d1 referred to as an injector relay
Chadbrapp
Oct 6, 2019 08:10 PM
Dubzyp
Mar 22, 2013 06:01 AM
Steven.singer
Nov 2, 2012 06:46 PM
THE BURGE
Dec 27, 2008 12:26 PM
