Discovery 95! Some questions..
Yes it is that bad, it will activate for no reason making the brake pedal hard as a rock and impossible to stop.
Many have run red lights and stop signs as this happens on plain old dry roads.
My wife almost rear ended a school bus one day, I pulled the ABS PUMP fuse that day after work.
It had done it to me once before, to her many times, the school bus incident was the final straw.
back to the codes ----- if the check engine light is on, that is on the left side of the dash cluster, and means there is a code. If the Service Engine Soon light is on, on the right side of dash cluster; that is a reminder that turns on to prompt you to have emissions serviced. It is triggered by a red "relay style" plug in under passenger kick panel. Remove and keep as paperweight.
To read the OBDI codes you MUST use the code reader box under the passenger seat, it will show you a 2 digit number, write it down, Google it.
The Rave will not give you the codes or what they mean.
If the code reader box is not working there is not much you can do other than unhook the battery for 15 min and hope the light does not come back on.
The ABS PUMP fuse, the only fuse you need to worry about, is under the hood in the under hood fuse box.
Lucas ECU fault codes:
Lucas 14CUX
FCR code Description
12 Mass airflow (MAF) sensor or MAF sensor circuit
14 Coolant temperature sensor (CTS) or CTS circuit
15 Fuel temperature sensor (FTS) or FTS circuit
17 Throttle pot sensor (TPS) or TPS circuit
18 Throttle pot sensor (TPS) or TPS circuit
19 Throttle pot sensor (TPS) or TPS circuit
21 Electronic control module (ECM) or ECM circuit (??queried)
25 Ignition misfire
28 Air leak
29 Electronic control module (ECM) memory check
34 Injector, bank A or injector circuit
36 Injector, bank B or injector circuit
40 Misfire, bank A or circuit
44 Oxygen sensor (OS) A or OS circuit (lambda sensor A)
45 Oxygen sensor (OS) B or OS circuit (lambda sensor B)
48 Idle air control valve (IACV) or IACV circuit
50 Misfire, bank B or circuit
59 Group fault - air leak or fuel supply
68 Vehicle speed sensor (VSS) or VSS circuit
69 Gear selector switch or circuit
88 Carbon filter solenoid valve (CFSV) or CFSV circuit
Lucas 14CUX
25 Ignition misfire
28 Air leak
Billabong
Jan 27, 2010 12:36 AM
StormTroopa
Aug 9, 2009 05:26 PM
97DISCOIDAHO
Sep 8, 2006 11:56 PM
