Discovery I stuck in the Mojave desert
Old Jun 4, 2016 | 04:37 PM
dsandor's Avatar
Default Discovery I stuck in the Mojave desert
Hi all,
A friend came up visting from san diego, and an hour before hitting vegas this hose blew out in 105 degrees.
Anyone know if this is the upper rad hose? The car is an hour from me and i should have taken better pictures, but I'm sure someone here knows. The local parts stores have the upper hose, but nobody has the multi-hose lower thingy.
Imgur: The most awesome images on the Internet
Thanks in advance - lets get this disco home.
Old Jun 4, 2016 | 05:57 PM
AbnMike's Avatar
Looks like the lower to me. The upper sits, well, upper. Runs from the top of the radiator to the top of the motor and into the thermostat housing.
Tell your friend some preventative maintenance and changing the hoses out would have prevented this - and time to change those oil cooler hoses, too.
Old Jun 4, 2016 | 06:07 PM
Shiftonthefly1's Avatar
I'm in Vegas if you need parts. PM me for my number if you need help or advice
Old Jun 4, 2016 | 06:40 PM
ihscouts's Avatar
I'd grab a fresh straight hose and some 1 1/4 pipe (could use PVC double barb for a short run - Home Depot). Cut 1 1/4" pipe about 3" long and attach it to the blown out lower hose with the smaller one and with new hose clamps around the cut back busted/fresh section. Cut straight hose to fit water pump and clamp it.. That would get the truck out of the sticks and into town.
ImQuattro
May 1, 2014 08:36 PM
Disco2Guy
Jan 6, 2009 09:02 AM
J. Toronado
Mar 26, 2008 02:52 PM
TeamSaluki
Off Topic
22
Nov 15, 2005 04:03 PM
05LandRover
May 4, 2005 01:04 AM
