Discovery upgrade to Defender 90 (D90) brakes - caliper and rotors?
One more question...
- I purchased the SS braided brake lines... is it possible to only change the front lines for now, and get to the rears in a couple of weeks, or should i tackle the backs at the same time?
if you have the time, it would be better to do it all at once. proper bleeding procedure starts at the farthest point from the master then moves to the closest. SO you would start in the rear and move forward. more time efficient to just do it all at once.
Just do them all at once and them bleed them once. I got the master cylinder adapter from Power Probe to use with my pressure bleeder. It's 100 times better than the Motive adapter.
Makes bleeding the whole system much easier.
https://www.tooldiscounter.com/ItemD...EaAuOBEALw_wcB
I had the conversion done on my D1. Worked much better, but not..great. We decided to remove my ABS completely, NOW, it works, much, much better.
With ABS removed the stock brake setup works better too.
When the ABS was removed, did they remove/bypass the pump and configure the ECU such that it won't throw codes?
Any caveats with removing the ABS entirely (e.g. insurance issues, vehicle inspections, etc.)?
