Do I need hub bearings?
Old Nov 5, 2017 | 05:48 PM
RedRovin''s Avatar
Default Do I need hub bearings?
I searched the forum and think I need new hub bearings but would like some verification first (tire shake video).
I'm also curious if the axle rotational play is okay or something I should look in to (spindle video).
Thanks
Old Nov 6, 2017 | 06:11 AM
aemnky606's Avatar
I would replace you swivel pin bearings top and bottom, thrust washers swivel pin, set your preload and replace your hub bearings at the same time. Check the rave out for the swivel pin. Section 54 page 10. Do both sides
As for the slight turning of the axle it looks fine to me.
AbnMike
Apr 21, 2016 06:32 PM
Externet
Nov 21, 2012 10:44 AM
adigerol77
May 6, 2011 03:29 PM
DISCOHAITI
Aug 27, 2007 09:09 AM
