Doh! I Overfilled My Gas Tank and Now Overheating!
Old Dec 12, 2019 | 04:09 PM
Disco Gusch's Avatar
Default Doh! I Overfilled My Gas Tank and Now Overheating!
Good afternoon team,
I just got my first Dico 1 running and its exiting to have. Today I accidentally overfilled my gas tank and after driving for a bit I noticed the temp gauge all the way to the H. It was cooling just fine before I overfilled the gas tank. My radiator hose is not building pressure and it's a new radiator system.
HELP!!!
Thanks,
Disco Gusch
Old Dec 12, 2019 | 07:48 PM
ihscouts's Avatar
Fan clutch, check it. Notoriously overlooked item.
Old Dec 13, 2019 | 09:31 AM
jimvw57's Avatar
There is a special timer/ counter on these trucks that makes the only have problems after you fill the tank, put new tires on, etc. (just kidding)
I would do a pressure check on the coolant system. Mine had that problem and it ended up being a bad cap, and a split coolant tank. Didn't overheat al the time, just when I worked it hard. I got a tester for the coolant system off Amazon for a reasonable price and it will work on almost all my cars. Makes troubleshooting much easier.
Old Dec 13, 2019 | 10:04 AM
WaltNYC's Avatar
cooling system issues are well chronicled. There is almost no chance your overfill was a cause.
What was the state of the truck before you started working it back into shape and what did you do?
rjlsierra
Sep 1, 2017 02:24 PM
starcraft1
Aug 15, 2013 10:32 AM
dammad
Dec 1, 2010 08:47 AM
Tropical Disco
Oct 27, 2009 12:52 AM
vandev
13
Jul 30, 2009 07:47 AM
