Dome Light
Old Oct 6, 2011 | 04:42 PM
thehun's Avatar
Default Dome Light
Ok..so i took my headliner out cause it was sagging really bad and didnt want to deal with it....so i disconnected my battery and started to take it apart.
Put it all back together....NO DOME light....this happened to me when I took my t-case solenoid out too..my transmission lights dont work either....thing is...i make sure my battery is disconnected before I start pulling plugs apart...and the bulb is not burnt...what gives
Old Oct 6, 2011 | 05:13 PM
ValveCoverGasket's Avatar
you should just stop disconnecting your battery before doing interior service
Old Oct 6, 2011 | 05:18 PM
lordmorpheus's Avatar
When replacing my headliner after painting it, I accidentally shorted the cargo dome light on re-installation. The bulb was fine, and it took 8 minutes of fuse checking with a multimeter to find the blown fuse because the manual was on the other side of the vehicle.
I didn't disconnect my battery, and should have. or just been more careful.
Old Oct 6, 2011 | 07:09 PM
Danny Lee 97 Disco's Avatar
You most likely either knocked something loose or shorted it to the metal somewhere.
I failed to disconnect the battery on my wife's Explorer one day. When a large wrench slipped and shorted something to ground, it glowed red pretty quickly.
Old Oct 6, 2011 | 07:27 PM
In addition to fuses the MFU could be at issue. Muti Function Unit, on the back of the interior fuse panel, and a PITA to get out. It does timing funtions, and has a big transistor in it that is not mounted to a heat sink. That guy "dims" the lights in steps. Mine had a small hole melted in the case, just next to that component. Figured it was from constant overload, without a heat sink that transistor is good for 1 or 2 watts in free air. You are running a lot more with front, center, and cargo lights. Changed my module and changed to LED lights, bright enough so I can check my depends after the Death Wobble...
Old Oct 6, 2011 | 11:15 PM
thehun's Avatar
Thing is though...I disconnected the battery...no electricity running through the car...and it still blew something...ill check the fuses to make sure
Old Oct 7, 2011 | 06:24 AM
DiscoBlanco's Avatar
Interesting....
I have noticed that my Dome light works, but does not come on anymore when the doors open. I replaced it with an LED. I went back to the incandescent, but no change.
I also notice that it takes my wipers about 2 seconds to respond once I turn them on.
Old Oct 7, 2011 | 06:46 AM
See https://landroverforums.com/forum/di...ighlight=light
and
https://landroverforums.com/forum/di...light=Internal
The RAVE has a test sequence that you can trigger to sequence through and test each of the functions of the MFU.
jigray3
Feb 22, 2019 06:29 PM
KennAR
Dec 26, 2012 04:20 PM
discomedic4
Apr 10, 2010 04:32 PM
dieselgeek
Oct 6, 2009 01:49 PM
sharonsbaby
Sep 26, 2007 09:10 PM
