Door lock pops up/won't go down
Old Jun 13, 2011 | 02:30 PM
wick_60010's Avatar
Default Door lock pops up/won't go down
I have a '99 Discovery I. When I hit the lock button on my remote (with all of the doors closed), the driver's lock goes down, and then pops back up right away. Actuator? Also, the lock on the passenger's door won't go down unless I physically push it down (replaced the actuator this weekend to no avail). Any suggestions? Thanks!!!
Old Jun 13, 2011 | 03:08 PM
tweakrover's Avatar
make sure the mechanism is lubed up and moving freely
Old Jun 16, 2011 | 09:28 AM
groundandpound's Avatar
My '96 did the same thing and the rod that connected the drivers lock to the actuator was bent inside the door and getting hung up.
Once that was corrected - no more issues.
Old Jun 16, 2011 | 01:12 PM
nevada ben's Avatar
I have this on mine... ok, if you power lock the doors, everything locks except the front passenger side door which you have to push down manually. But if you power unlock the doors, everything unlocks except the rear passenger side door. You have to unlock it manually.
I think those guys over in Solihull are a bunch of drinkers. I mean, you almost have to try to deliberately screw this stuff up.
Old Jun 17, 2011 | 09:18 PM
skyguy's Avatar
Nevada Ben that is a passenger door actuator issue you have. I had same problem and replaced the actuator and problem was solved
kristofferzen
Sep 10, 2015 02:11 PM
kpl1228
Aug 19, 2012 05:33 PM
roverrick
Nov 23, 2007 01:49 PM
roverrick
Nov 23, 2007 01:41 PM
