Driver's Rear Window (Beating a Dead Horse)
Old Jun 13, 2013 | 01:45 PM
Toyfare's Avatar
Default Driver's Rear Window (Beating a Dead Horse)
To beat a dead horse, I rolled down my windows the other day and my driver's side rear window won't roll back up. At first the motor made noises, now it won't. I pulled the motor and tested it with a 12V connection, it works fine. I've tried swapping out the switch with another that works, still nothing. The other rear window operates normally. Would the window ECU with a bad solder joint just let one window not roll up?
Also, if I can't get this worked out, how can I get the window to stay up. My redneck duct tape is melting in the sun and can't hold the window up.
Old Jun 13, 2013 | 02:17 PM
petedisco's Avatar
the ecu is a problem because the solder joints come loose especially from disconnecting the plugs. One front window can be effected or both backs yanking the plug with a suitable plyer makes more connections bad.
Old Jun 13, 2013 | 02:56 PM
Toyfare's Avatar
Alright, I'll give it a shot. Will post the results. Possibly pics!
Old Jul 8, 2013 | 09:49 AM
Toyfare's Avatar
Resoldered most of the connections on the window ECU to no avail. Took out the regulator and motor. Motor tested fine on an alternate 12V source. Had to order a new regulator.
Other windows still work fine, I have tested a working switch on this window and still nothing. Will try the motor today to see if it will work in vehicle.
Old Jul 12, 2013 | 12:51 AM
jonodesf's Avatar
7th Gear
i have the same problem with my 1999 D1. i change out the ecu but the back passenger side is still not working. could it be the motor/regulator?
Old Jul 12, 2013 | 09:24 AM
Toyfare's Avatar
Check the wire going to the motor, no power when switch is pushed. Put in new regulator and used a lawn mower battery to jump the motor to roll the window up. Guess I won't be using that window anymore!
Old Jul 13, 2013 | 10:38 AM
jonodesf's Avatar
7th Gear
Sounds like you have a loose connection somewhere going to the motor. the ecu problem usually affect both rear windows. the common problems are the ecu, or the motor, or the regulator would have a bad guide bushing, which can be replaced with a cheap mod, or the switch. your problem seems more complicated. there's a rear windows bypass mod but not sure if that will solve your issue.
got the ecu i ordered on ebay and put it in. rear right window is still not working. pulled out and check motor/regulator and it seems my motor is on it's last breath. used a spare car battery to check and it's barely moving outside. when inside it just made a slight noise but did not move the window up or down. bought another motor/regulator unit from ebay and waiting to replace it. hope it will work this time.
tattoogunman
Apr 25, 2014 09:39 AM
Dodger
Dec 7, 2011 07:49 PM
73S3IP
Sep 26, 2008 11:00 AM
rover on over
Jul 17, 2008 10:38 PM
trebby67
Nov 27, 2006 10:41 PM
