Drivers side window won’t move at all!
Old Feb 25, 2021 | 11:00 AM
jcypress97's Avatar
3rd Gear
Default SOLVED: Drivers side window won’t move at all!
Hello all, just bought a disco I and i am loving it so far. However my drivers side window will not move at all. I am at a complete loss. Fuse is good, resoldered the bcm, tested the volts at the motor and i am getting around 5 volts. I looked for broken wires in the door but I’m still on the chase. The switch is good too... what else am i missing?
Old Feb 26, 2021 | 04:12 PM
dos531's Avatar
Maybe because you're only getting 5 volts?
Old Feb 27, 2021 | 08:43 AM
jcypress97's Avatar
3rd Gear
Yeah i know I’m supposed to get around 12 volts. I just dont know where to look. Cleaned the grounds too and no luck
Old Feb 27, 2021 | 09:54 AM
WaltNYC's Avatar
Check the motor..... run 12 volts directly from your battery. Any life?
Not to insult but..... are you confident in your use of the multimeter? We can all do flakey things from time to time. I know I sure do.
Old Feb 27, 2021 | 10:10 AM
jimvw57's Avatar
had that issue and it was a bad solder joint on the circuit board I overlooked
Old Sep 4, 2021 | 07:51 PM
jcypress97's Avatar
3rd Gear
Default Solved the issue!
There was a broken component on the bcm that i had soldered. Hooked everything up then i found out my window motor was shot so i changed that and success! All windows are finally working
Tomzsix
Aug 21, 2019 06:16 PM
CollieRover
Nov 21, 2014 12:45 PM
Bob Jones
Jan 1, 2013 10:59 PM
baysiderover
Oct 28, 2008 08:06 AM
01DiscoII
Apr 9, 2008 03:57 PM
