drivers side window won't go down
Old Jun 4, 2012 | 11:56 PM
jbunner's Avatar
Default drivers side window won't go down
My drivers side window won't go down. I can hear noise when I push the up button, but not when I push down button. Does this have points you can clean? I wondered if it was caused by the excessive heat coming from the console. Thanks
Old Jun 5, 2012 | 04:16 AM
Maybe just a wire knocked loose from the switch panel. Switch can also go bad, etc.
Old Jun 5, 2012 | 05:57 AM
jbunner's Avatar
I will have to get fixed because of inspection. I am going to check wiring today. Thanks.
Old Jun 5, 2012 | 07:15 AM
may also e off track inside door
Old Jun 5, 2012 | 08:37 AM
slanginsanjuan's Avatar
if you hear the motor chances are it's not the motor. could be tho. you can swap with another to test.
really you'll have to pull the insides off and see what's wrong. if the motor is ok, check the movement of the regulator arm. if it's not moving freely chances are the roller is bunged up. you can replace that as per the sticky.
if it's not dealt with and it hasn't happened already the regulator can bend. sometimes it can be bent back but more often than not you'll need a new one.
Old Jun 5, 2012 | 08:48 AM
Jake1996D1's Avatar
I have a working motor and regulator if you need it. Unsure of the plastic rollers because it's still in the door. PM me if interested
twoxred
Oct 4, 2021 07:07 AM
archaeology_student
Oct 30, 2013 09:33 PM
Newfoundlandrover
Oct 2, 2011 06:51 PM
scwkof
Jan 16, 2010 10:28 PM
baysiderover
Oct 28, 2008 08:06 AM
