Driveshaft Question
Old May 7, 2014 | 12:14 AM
calebbo's Avatar
Default Driveshaft Question
95 D1. Lifted with HD TF +2" kit.
I'm pretty sure it raised it over 2" since I have no weight in the vehicle. Do you guys recommend just getting DC U-Joints installed or just upgrade both shafts? The reason I am asking is because on great inclines I hear this crazy noise and feel a thudding from the floor panel. Assuming it's the shafts.
Old May 7, 2014 | 12:54 AM
CUpgt's Avatar
DC front, stock u joint rear should be fine
Old May 9, 2014 | 07:46 AM
Sam95disco's Avatar
I didn't change the front shaft, only the rear. It feels the same before and after.
Old May 10, 2014 | 11:14 AM
calebbo's Avatar
Whats the part number for the DC?
1-0005?
Or did you mean buy a DC shaft for the front and replace the rear u-joints haha
Old May 10, 2014 | 12:05 PM
CUpgt's Avatar
You probably don't need a new front shaft but the economical way to do it is to buy a used d2 and rebuild it with greasable joints
Old May 11, 2014 | 01:43 AM
calebbo's Avatar
Buy a used D2 drive shaft. What part number goes to a D2 drive shaft? I can't use those same u-joints on a D1 shaft?
Old May 11, 2014 | 08:59 AM
CUpgt's Avatar
U joints are the same. Precision 744 I think. Look in the tech section at drive shaft rebuild. You will need a d2 transfer case output flange though.
Old May 11, 2014 | 09:05 PM
LRadventure's Avatar
The D2 front axle shaft has a double cardan, wich will clear up your drive angle issue, i also used the camber correcting bushings for the radius arms. I had sever vibration before i changed those two items, now she smooth as silk.
Old May 12, 2014 | 07:24 AM
TOM R's Avatar
Doesn't a 95 have the rubber coupler at the back diff instead of a u joint? If so get a newer d1 rear shaft with the pinion flange from the diff for u joint, and drive shafts you put in should be rebuilt with new u joints, when they go it is not pretty sometimes
robert.juric
Nov 3, 2022 06:08 PM
Mark G
Apr 22, 2016 06:55 PM
NiteTrain
Jul 21, 2008 06:40 PM
nyqt83
Apr 12, 2008 11:01 PM
xb70valkarye
Nov 24, 2007 12:20 AM
