Electric Cooling Fan Replacement Options
Old May 13, 2018 | 06:35 PM
deer4011's Avatar
Default Electric Cooling Fan Replacement Options
The two fans in front of the radiator on my 98 disco no longer work. I took them both out and tested them and one spins really slow and the other not at all. I also noticed them acting the same while on the car so I know they're getting power. I live in Texas and it isn't even hot as it's going to be mid summer and it overheats with the A/C on in traffic on when I'm crawling around on the trail. Amazon has the OEM fans for a cool $450 but I was wondering if anyone has replaced these with another brand/style/etc. that doesnt cost $450. I also ordered a fan clutch because the one on there right now probably hasn't been changed and spins pretty freely.
Old May 14, 2018 | 08:28 AM
WaltNYC's Avatar
here....
Amazon Amazon
or here....
Amazon Amazon
this may help too....
https://landroverforums.com/forum/di...ikes-ac-86572/
Old May 16, 2018 | 08:51 PM
Best4x4's Avatar
The efan out of a 90's Toyota Corolla is the exact same unit as the D1. When I had my D1 I grabbed several from a pick n pull type yard for like 5.00 each. I did not keep the fan surround or the fan blades. I grabbed just the efan motor's themselves, removed my old & dead LR unit's cut off the OEM harness, used two butt connectors per efan motor, and re-installed them. Zero issues and done for 10.00.
It will be the smaller efan for the AC not the engine efan on the Toyota Corolla btw.
GURU06
Oct 17, 2017 09:09 AM
Broken08
Sep 5, 2016 09:39 PM
CANAMDiscovery
Jan 25, 2013 07:22 AM
sickws6
Dec 8, 2011 04:52 AM
vonfonk
May 6, 2006 06:50 PM
