Electrify the Disco
I don't know that Disco's could ever manage the steep roads in CO ...LOL! Mine didn't do so well out there.
There exist now (I believe now ...or soon to be out) OEM aftermarket automotive electric drivetrain conversion kits. They're new on the market, they were previously delayed, but I think they might be out (for purchase) now. Ford has the Mach-E, and GM has the eCrate kit. The GM kit might even bolt to the Disco (??). I've read about other aftermarket kits too, but haven't checked them out in a while. You should search what's out there. Probably a number of youtube videos on them. We're at the cutting edge of electric retrofits. But then, given enough money, time and fabrication work a person could definitely get an electrical conversion to work. Esp as expensive as it is to rebuild a Disco/Defender engine. The Disco is it is already a very heavy vehicle, which will only get heavier after the batteries are added, that's a negative. Going uphill will be an energy-sucker but at least you'd have instant power. For instance, Motor Trend just did a shoot-out amongst the Hummer EV and Rivian electric pickups. Towing cut the economy in half. But it does almost the same towing with a gas engine. But hauling a 1500# weight only cut the economy penalty by 4%.
But deinitely do your own research. I'm not really up on the latest in electric conversions and the technology is rapidly evolving. What was true a few months ago might not be relevant this month. I would say whatever cost you estimate, double it ...if not tripple. Eventually someone will do a conversion of a Defender (or Disco) if they haven't already.
Sounds like a fun project though. OTOH, the Rover engine has a lot of HP potential. They've used them for racing. You might search out HP options. It's going to be really expensive to rebuild a Rover engine ...almost, like you say, a guy could do an electric drivetrain conversion for less.
alfsf40
04-24-2011 01:00 PM
