engine code P0138 0- what to do..
Old Sep 21, 2010 | 02:41 PM
tango123's Avatar
Default engine code P0138 0- what to do..
I have a 1997 discovery with 145K on it. I recently changed all the 4 oxygen sensors.
Occasionally my engine light would still turn on, and this is the error code that it would produce..
P0138 - H20S Failure to switch to lean. Bank A.
What does this mean? Is it one of the oxygen sensors is malfunctioning?
If it is, which one is Bank A?
Old Sep 22, 2010 | 11:18 PM
demonlarry's Avatar
are you using a generic OBDII reader?
if I recall correctly, the 0138 code is related to the O2 sensors after the cat. generally either bad O2 sensor or the wiring going to it.
Check it out further, though.
Old Sep 23, 2010 | 07:17 AM
XCELLER8's Avatar
I agree with demonlarry....P0138 " o2 sensor circuit high voltage ( bank 1 sensor 2 )
that's drivers side sensor behind the cat.....
Lr3pete
Apr 12, 2014 10:10 AM
hatt53
Mar 27, 2013 05:16 PM
pixel
Mar 5, 2012 12:29 PM
sayeedA
Nov 15, 2011 11:02 PM
