engine does not switch off with key on disco 1997 300 TDI
Old Mar 25, 2012 | 05:49 AM
Manumaputo's Avatar
3rd Gear
Default engine does not switch off with key on disco 1997 300 TDI
Hello
It happened to me sevelal times but this time I can't fix it:
my car is running and when I stop and want to switch off the engine by turning the key, the engine carries on turning, I need to stall to stop it but then all the light indicators in the car are lighten like if I was with the key in the last position before starting the engine.
Usually all I needed to do was deconnect the battery and connect it again and all got reinitialized again.
this time the trick does not work and I tried to dismount the electric connectors (it is a small black round connector box that fits into a mechanical device that turns with the key), I did not manage, as the box seemed sealed.
Do you know how to dismount it and if this is going to be the problem? or should I look somewhere else?
many thanks
manu
Old Mar 25, 2012 | 10:38 AM
Does sound like your switch needs replacement. Until repaired looks like you could pull fuse 3 in satellite panel under dash to drop power to fuel solenoid. MAy need to rig a temporary switch.
File Type: pdf
Old Mar 26, 2012 | 08:28 AM
leadfoot's Avatar
I am not familiar with the TD300, but most diesels use a vacuum diaphragm to shut off. I had Land Cruiser diesel that I had to put a hose in the diaphragm and run into the cab and suck in every time I wanted to shut it off until I found the leak and repaired the problem.
dirkha
Feb 10, 2021 06:44 AM
Manumaputo
Mar 25, 2012 05:33 AM
Phil8
Dec 6, 2009 04:21 PM
truckerdan155
Apr 25, 2007 12:33 PM
hanyshamloul
Dec 20, 2006 07:43 PM
