Engine Oil Pressure Adaptor
Old Mar 18, 2011 | 10:38 AM
Chris-bob's Avatar
Got this from another site.
I guess if you get the oil cooler adapter(the sandwich part) you can mount an oil pressure sending unit to it.
Oil COOLER
The oil cooler is fed off the "oil cooler adapter' which is sandwiched between the oil filter housing and the block. For a IIa, the feed line should arc over the engine (behind the water pump) to a junction on the inside of the LH wing. This is where the oil-temp capillary sender connects. After the cooler, oil returns directly to the sump (oil pan).
OIL PRESSURE
The Mechanical oil pressure line should attach to the oil filter housing. You will attach the oil pressure line between the oil pressure warning switch and the oil filter housing, using a banjo fitting. You do not need to disturb the oil cooler lines at all.
Old Mar 18, 2011 | 10:43 AM
Chris-bob's Avatar
Wise Owl Innovations Incorporated - Land Rover Parts
This may be what you are thinking of...third item down.
Old Mar 19, 2011 | 10:59 AM
Danny Lee 97 Disco's Avatar
Guys,
Check this one out. I would go with this type.
Oil Filter Sandwich Adapters
They have the adapters, guages, and everything needed for simple addition of good oil pressure/temp guages.
Old Mar 19, 2011 | 07:41 PM
Chris-bob's Avatar
Originally Posted by Danny Lee 97 Disco
Guys,
According to the site, the adapters come without any senders, gauges or wiring. Just pointing it out so no one buys one thinking it's a kit in a box.
Old Dec 7, 2012 | 10:13 PM
sochuck's Avatar
Default flare back
Just to bring up this dead horse. I noticed that everyone that has done this left the adapter down at the OE location running a tee or whatever adapter there. I was wondering about having a small hydraulic hose from the mounting point for the sending unit to a more, uh, advantageous location...any thoughts?
Old Dec 8, 2012 | 07:53 AM
04duxlr's Avatar
Depending on how and where you mount it you might need to bleed it so it provides accurate readings but it should work. Just make sure you use a very good quality hose. A braided stainless line would be a good choice. If the hose breaks while you are driving you will roast the engine in no time.
Old Dec 8, 2012 | 08:02 AM
I would point out that if plumbing allows, having both the oil switch and the gauge are a good idea. If the idiot light was wired to make an noise (and mute the radio) even better. SWMBO's as a group consider red lights (at intersections and on the dash board) as challenges to be overcome by pressing on regardless. I prefer the electric sender method, I've had an oil line to a gauge let go under the dash and it is messy. If going mechanical, there is a nylon hose for the pressure line that can be used instead of copper, it does not conduct engine noise into the cockpit as much.
Old Dec 9, 2012 | 01:56 PM
ValveCoverGasket's Avatar
i did this with the sandwhich adapter, which allows you maintain all the stock functions/sensors as-is
fits fine with the big filter as well
mechanical oil pressure gauges are a terrible idea (in my humble opinion of course...). just run electrical stuff off of a sender and never worry about lines fatiguing or rubbing through and causing a fire/dumping oil on your feet when it breaks loose in the dash.
drowssap
Jul 6, 2012 07:15 AM
HelenaRover
May 7, 2011 12:19 PM
Classklown90
Audio/Visual Electronics
Jan 12, 2010 11:36 AM
mputnam
Mar 12, 2009 01:45 AM
