Engine overheated
Old Sep 17, 2024 | 05:16 PM
rfwj's Avatar
Default Engine overheated
I messed up and drove at hot level. Now my gems engine has a nasty squeal coming from the engine. It is not the water pump as I disconnected the belt and the squeal is still there. I fear I ruined the engine. It sounds like rubber squeezing in the engine under the valve cover. Any thoughts that maybe the engine could be fixed like something the valves could be fixed. Timing chain? Thanks
Old Sep 18, 2024 | 07:21 AM
WaltNYC's Avatar
Very difficult to diagnose any specific injury based on the description of a sound.
- how long was the vehicle run in an overheat condition?
- do you know how high the temperature was during the overheat condition?
- did you lose a significant quantity of coolant?
- have you tested for exhaust gasses in the coolant?
If you think the sound is coming from under the valve cover, pull the valve cover and visually inspect the rockers, springs, and valve stems. Take a picture and post it here.
Old Sep 18, 2024 | 08:19 AM
rfwj's Avatar
I ran for five min very hot. Coolant leaked out as I thin the thermostat got stuck closed. I think I will tow it to a mechanic.
Old Sep 18, 2024 | 11:34 AM
Toran's Avatar
Gotta check your fluid levels.
Where is the coolant leak located?
Old Sep 18, 2024 | 06:11 PM
JohnZo's Avatar
Only thing that I can imagine would "squeal" is a massive vacuum leak if a gasket gave way, even that is a long shot. Good to have a mechanic look it over. Let us know how it goes, please.
Phydeaux1
Sep 18, 2018 05:13 PM
Birdperson
Sep 4, 2017 12:44 AM
golgafrinch
Apr 5, 2016 05:55 PM
elrocha69
May 13, 2008 02:16 AM
mrach21061
Apr 25, 2007 11:54 AM
