Evap canister
Old Oct 16, 2018 | 11:15 AM
dicksoutforharambe's Avatar
Default Evap canister
im looking to replace my evap canister and or purge valve. AB says it’s discontinued by Land Rover and no longer available. Was wondering if anyone knows about a compatible purge valve for the non advanced evap system? Thanks
Old Oct 16, 2018 | 05:02 PM
aemnky606's Avatar
Dorman 911-800 Fuel/Emissions Purge Valve for Hyundai/Kia
Amazon Amazon
I replaced mine with this one and it has been working great.
Old Oct 16, 2018 | 07:24 PM
Thanks for responding. That seems like an inexpensive solution even if it doesn't work I won't be out much money. My D1 runs fine but it's throwing the p0441 code and I wanted it to go away so I could pass my emissions test. I was wondering if that cleared up your check engine light?
Old Oct 16, 2018 | 08:03 PM
aemnky606's Avatar
I'm not 100% sure that was my issue. I had a large evap leak and the purge valve would stick open. I also found a few leaks in my fuel fill hose and lines around the tank. I fixed the leaks and replaced at the same time and have not had any codes for that any more.
Old Oct 17, 2018 | 09:21 AM
Paul Grant's Avatar
If you need the canister, I have a number of good used ones on hand with and without the purge valve on top. IIRC, the purge was on top for the 14CUX models whereas the early GEMS version did not.
Antmen
Jan 11, 2020 06:52 PM
cammyr01
Nov 6, 2018 11:10 AM
aemnky606
Mar 25, 2017 07:16 AM
Rover Chris
Feb 13, 2011 09:45 PM
racer11x
Freelander
Jan 18, 2009 08:46 AM
