Exhaust Manifold
Old Jan 5, 2013 | 02:23 PM
Rearden Steel's Avatar
Default Exhaust Manifold
I was working towards changing my transmission filter/fluid on the D1. I also planned on replacing my exhaust gaskets at the heads and the manifold/pipe as I have multiple leaks. I broke the studs on the drivers side manifold. I have the forward exhaust pipes disconnected but hanging.
What is the easiest way to get the drivers side exhaust manifold out so I can replace the studs? The passenger side came out the top. But short of disassembling the steering shaft, I can't see how I getting it out of there.
TIA
RS
Old Jan 5, 2013 | 05:19 PM
antichrist's Avatar
It should come out without removing the steering shaft.
Old Jan 5, 2013 | 07:23 PM
JPSpen's Avatar
What problem are you having ? Can't get a tool on a particular bolt/nut ?
As far as tasks on the Rover go.. Taking apart the steering shaft is about as simple as it gets...
John
Old Jan 6, 2013 | 06:46 PM
Thank you AC..........and under the category of "I am a dumb-***"....for documentation purposes. I removed the heat blanket from the steering shaft assembly. Turned the steering wheel 90 degrees thus rotating the knuckle out of the way and the manifold came right out.
Attached Thumbnails Exhaust Manifold-imag0591.jpg   Exhaust Manifold-imag0592.jpg
twaszak
Jul 15, 2012 07:21 PM
Smorgan2004
May 28, 2007 06:50 PM
raid13
May 13, 2007 10:22 AM
portman
Jan 3, 2006 05:26 AM
beavis4g63t
Jul 12, 2005 05:27 PM
