Exhaust Manifold Bolt Question:
Old Jul 11, 2011 | 10:49 AM
Rearden Steel's Avatar
Default Exhaust Manifold Bolt Question:
Do the exhaust manifold bolts come out without issue? Or do they typically break?
Will typical grade 5 or grade 8 bolts work as replacement?
TIA
RS
Old Jul 11, 2011 | 03:05 PM
LRD2&ME's Avatar
From: Oklahoma; where the winds come rolling down the plains.
Spray PB Blaster generously and they should be fine.
Old Jul 11, 2011 | 03:22 PM
XCELLER8's Avatar
of the 3 Rovers I've had apart , all the exhaust bolts came out without much problem...except for the D2 I did which had apparrently been "loctited" extra at the factory....they needed to be heated just a little to soften the loctite so they would turn out
I replaced mine with grade 8..
Old Jul 12, 2011 | 12:11 AM
mordor110's Avatar
Most of mine have come out ok, some have pulled out a coil of aluminum when they came out though. Odd ball metric thread size from what I can remember. I have trouble finding the correct thread pitch, unusually fine for the size of bolt? Think it was a 1.25mm pitch?
Old Jul 12, 2011 | 08:37 AM
XCELLER8's Avatar
remember.....these heads are old Buick parts....all of the disco's I have worked on have standard sae threads 3/8"-16 for the exhaust bolts, I usually run a tap in all the bolt holes just to clean them up before re-installing the new bolts
Francopacks
Feb 15, 2023 07:08 PM
acamato
Oct 20, 2014 08:49 PM
SemperFiDisco
Jan 31, 2013 06:01 AM
twaszak
Jul 15, 2012 07:21 PM
Chrisinhouston
Dec 30, 2009 06:40 AM
