Exhaust Manifold Bolt Question:
of the 3 Rovers I've had apart , all the exhaust bolts came out without much problem...except for the D2 I did which had apparrently been "loctited" extra at the factory....they needed to be heated just a little to soften the loctite so they would turn out
I replaced mine with grade 8..
Most of mine have come out ok, some have pulled out a coil of aluminum when they came out though. Odd ball metric thread size from what I can remember. I have trouble finding the correct thread pitch, unusually fine for the size of bolt? Think it was a 1.25mm pitch?
remember.....these heads are old Buick parts....all of the disco's I have worked on have standard sae threads 3/8"-16 for the exhaust bolts, I usually run a tap in all the bolt holes just to clean them up before re-installing the new bolts
acamato
Oct 20, 2014 08:49 PM
twaszak
Jul 15, 2012 07:21 PM
