Exterior Power Wire Routing.....wise?
Old Jun 15, 2012 | 12:54 PM
wheelgarage's Avatar
Default Exterior Power Wire Routing.....wise?
In my quest to finally wire up the lights on the rack and add a power source to the rear, I am trying to figure out how to route the power wires from the engine compartment to the rear passenger rear.
I can go though the interior, routing above the tunnel then back up the side panel. But... what about routing them from the engine compartment, down to the frame rail, passenger side, then up the trailer harness plug?
I can see A/C plumbing and all the fuel lines. Is it safe? From looking at the RAVE electrical harness routing, they completely avoid this area....?
Here is what I am routing to....
Old Jun 15, 2012 | 01:19 PM
Jake1996D1's Avatar
Yea it's safe but you could just as easily run them inside under the panels near the doors and across behind the rear seats. The only bad part about wiring being outside is that it is exposed to the elements.
Old Jun 15, 2012 | 03:29 PM
ValveCoverGasket's Avatar
use proper gxl/txl wire and dont worry about it... NOT the random spools of crap at autozone or napa.
id probably run it inside just for neatness sake, but good gxl/txl should have no problem living outside under your truck.
Old Jun 15, 2012 | 05:01 PM
Yeah, that was the plan. I wish it was 20 degrees cooler, just cant stay out there that long to do it. I wish the Disco can fit in the garage again....so I can just take it apart in a nice cool area....
Okay, I have everything to route the wires under the body (under shade) and protect them for all the elements. Once the weather cools down, I can then recycle the wires and route though the interior properly.
Thanks ya'll for the feedback...
ImQuattro
Sep 8, 2014 06:14 PM
cmb6s
Jul 13, 2014 09:45 PM
RichardBlank
Off Topic
Dec 23, 2008 05:53 PM
Dino76
Aug 19, 2007 10:21 PM
hiljak
Jun 25, 2007 12:37 PM
