FCC ID# for remote replacement
Old Jun 8, 2016 | 08:22 PM
dsmeddy's Avatar
Default FCC ID# for remote replacement
How do you tell the FCC ID# on a particular land rover discovery for purchasing a replacement key fob (I have no key fobs at this time)
Old Jun 8, 2016 | 09:24 PM
Joemamma1954's Avatar
Getting a replacement key fob and having it programmed can be expensive. This is the route I went. You order the replacement key with FOB and they send you a new key(uncut) and a programmer, that you plug into your diagnostic port and use a good key to turn on the ignition and wait for 10 seconds. You then can go to locksmith and have the key cut. You send the programmer back and he refunds you 30.00 and emails you the EKA code.
total cost is around 150.00 compared to over 300 for key and programming from Dealer.
I had key but no FOB, now I have new key and working FOB.
Land Rover Discovery I 1995/6 - 2000 Key Fob Problems and Repair
Old Jun 8, 2016 | 09:26 PM
In answer to your question, tho. I have no idea.
Old Jun 8, 2016 | 10:33 PM
XCELLER8's Avatar
just a thought....look on the alarm system ecu...maybe there's a number on that
accessories4less
Jan 29, 2019 12:51 PM
RROJ
Oct 9, 2010 07:39 AM
RROJ
Oct 8, 2010 09:56 PM
compfranon
LR2
Jun 23, 2010 01:42 PM
