a few question 98 disco
Old Dec 14, 2011 | 10:12 PM
  #51
Danny Lee 97 Disco's Avatar
The replacement of the switch DOES NOT REQUIRE REMOVAL OF THE STEERING WHEEL OR COLUMN.
It is pretty simple. Remove the plastic shroud from around the ignition switch.
Crank the steering wheel hard to the siode to get the inner part of the wheel of your way so you can see the 4 small phillips head screws that hold the switch in.
After you remove the screws, it take some finger strength or a small flat blade screwdriver to help ease the part out of where it sits. You have to pull it straigh out from where it sits, it is not real easy, it does not release easily, but it does come out with a little convincing. And since you are replacing it, you do not have to be that gentle with the old one.
Old Dec 15, 2011 | 11:53 AM
  #52
olywa's Avatar
I figured it out thanks everyone. Now on to the next issue. When I get home I'll explain more. It wasn't the switch. Wire issues.
Old Dec 23, 2011 | 12:45 AM
  #53
olywa's Avatar
the previous over had a switch the turned off the headlights and switch. that what was causing it to cut out the headlights.
RangeRovering
Nov 3, 2007 05:11 PM
amvauto
Aug 16, 2007 07:50 AM
dbwarren
Nov 14, 2006 07:14 PM
Suzanne017
Jun 22, 2006 09:53 AM
xadamx
Mar 1, 2006 01:42 AM
