a few question 98 disco
Old Dec 6, 2011 | 10:32 PM
  #31
LeakyDisco's Avatar
Originally Posted by olywa
I have check them some didn't light up my tester. Now my battery is dead from having the lights while I check everythig. Rookie mistake. And my wife Subaru won't jump it. It's been hooked up now for at least 5 minutes. This is getter worse by the minute.
Hmm...sounds like you must have a weak battery, too, unless you left lights on for a couple hours or more.
Remain persistent and you will figure it out.
Old Dec 6, 2011 | 11:31 PM
  #32
olywa's Avatar
my cables were crap and i used a newer pair and it started up. i had my 4 hella lights on while i was working a the radio, but the baterry might be not the strongest.
I tested the fuses with the engine running but not the lights on. The results:
2,4,5,8,10,11 the check 10 and it wasnt blown, didnt check the rest.
Old Dec 7, 2011 | 11:22 AM
  #33
LeakyDisco's Avatar
If your fuses are good, then it probably makes sense to try replacing the switch or at least pulling it and seeing if there is a way to test it to eliminate it as the cause.
Old Dec 7, 2011 | 12:10 PM
  #34
Danny Lee 97 Disco's Avatar
Originally Posted by Spike555
RoversNorth, while a great resource because of their diagrams and such, is the most expensive place to buy parts other than the stealer.
Switch Directional/Headlight | Land Rover Electrical Parts, Batteries, Relays, Lamps & More
I bought a used one from Will Tillery for Forty Five Bucks and that included shipping.
Old Dec 7, 2011 | 11:36 PM
  #35
olywa's Avatar
I found the part on the forum. Great deal also.
Old Dec 8, 2011 | 07:14 AM
  #36
antichrist's Avatar
my new to new discovery has some quarks.
Which flavors of quarks? Up, down, strange, charm, bottom, or top?
Being a Land Rover I'm guessing most would be classified as strange.
Old Dec 8, 2011 | 08:44 AM
  #37
Particle physics and we can't get people to clean their battery terminals....
Old Dec 9, 2011 | 12:10 PM
  #38
olywa's Avatar
I want to check the rest of the lamp but afraid if I fiddle around with them something else might get shorted.
I need to figure out how to repace the driver front blink the housing and the connector are corroded.
Old Dec 9, 2011 | 12:36 PM
  #39
here you go, from workshop manual in the RAVE, electrical section
File Type: pdf
Old Dec 9, 2011 | 01:19 PM
  #40
olywa's Avatar
The wire that goes into engine carpartment is also corroded. Is that replaceable? Wire #2
Is the diagram for front directional.
