A Few Questions, All About Water Leaks
Old May 30, 2012 | 11:35 AM
oilspotLR's Avatar
Originally Posted by s10lowrider1994
Been hard at work and got most of it fixed. Here's what I found:
Both front and rear sunroofs leaks around the seals. Both assemblies had very loose hardware, basically ever bolt was loose. Snugged up everything on front and rear sunroofs, did an high pressure water test and the leaks are gone. Also cleared out all of the drains and resealed them to the housing.
Rear door poured in around the top all the way across. Adjusted the latch and hit the seal with gum I pledge a few times and that leak also went away.
The roof rails were also hand tight and letting in a bit of water during hard rain. A few turns of the ratchet solved that.
All I'm left with is a windshield that leaks in the upper right corner if you blast it with water. Rain isn't enough to make it leak nor is a garden hose but the car wash or pressure washer will make it leak pretty good. Can I just run a bead of marine silicone around the inside and call it a day or do I need a new windshield?
Make sure you remove the black trim before you seal the windshield.
Spencerfitch
Sep 27, 2020 12:17 PM
mmb
Dec 1, 2014 11:11 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
hhalimi
Feb 13, 2012 04:10 AM
