Firewall pass through for wiring
Old Nov 13, 2020 | 09:22 AM
Mike Cork's Avatar
6th Gear
Default Firewall pass through for wiring
I see several posts that reference a hole in the firewall on D2s...is there one on D1s as well (cuz I sure as hell can't find it). I'm trying to run a power wire for an amp, and would rather not drill through the firewall if I don't need to. Any help much appreciated!!
Old Nov 13, 2020 | 09:24 AM
logan_gibson's Avatar
Should be one on the drivers side near/on the pedal box.
Old Nov 14, 2020 | 07:31 AM
Toran's Avatar
That is the one I use.
Old Nov 14, 2020 | 08:04 AM
robertf's Avatar
Thats only available on automatics
Old Nov 14, 2020 | 08:11 AM
Toran's Avatar
This is one my 96 5-speed.
Old Nov 15, 2020 | 01:21 PM
Mike Cork's Avatar
6th Gear
Gotcha...so nothing on the passenger side (more convenient to battery)? May just drill at this point...dunno.
Old Nov 15, 2020 | 01:26 PM
Toran's Avatar
I think there is also an entry point on the passenger side too. My issue was the washer fluid reservoir being a bit in the way. From inside the truck there is a lot of wire connection action going on under the passenger footwell so I would say yes it can be done.
Old Nov 16, 2020 | 07:40 AM
Pass Side, no holes. But you could go through the factory harness grommet (I wouldn't.). I would pop out the retaining clip next to the inertia switch and use the hole that provides.
Drivers Side, I would use the grommet on the top left there. Just above the hood latch cable.
Otherwise you need to push the grommet out above the throttle cable (Assuming you have an automatic) and use that one. (Much larger).
greisinb
Mar 27, 2020 10:10 PM
bballjames
Jun 22, 2012 04:50 PM
tailchaser0527
Audio/Visual Electronics
Sep 30, 2008 02:37 PM
ensign42
Apr 1, 2007 06:03 PM
