Flickering headlamps 97 Disco
Old 11-24-2013 | 12:18 PM
Britchick1980's Avatar
Default Flickering headlamps 97 Disco
So new problem. When driving I'm experiencing flickering headlamps. They're not going out totally, but like flickering between high and low beam. Any clues?
Old 11-24-2013 | 12:45 PM
coors's Avatar
1.) Check your battery connections. Make sure both positive and negative terminals are tight. They do come lose fairly often.
2.) possibly faulty switch/stalk. There's a write on how to replace the stalk w/o having to remove the steering wheel.
Old 11-24-2013 | 12:59 PM
Thank you Coors.
Originally Posted by coors
1.) Check your battery connections. Make sure both positive and negative terminals are tight. They do come lose fairly often. 2.) possibly faulty switch/stalk. There's a write on how to replace the stalk w/o having to remove the steering wheel.
Old 11-24-2013 | 03:35 PM
jimvw57's Avatar
Noticed this on my Disco when I first got it running. I was changing the belt and tried running the motor without the belt to see if it had any effect on the lights. They stopped flickering with the belt removed. I replaced the Alternator with a used one (cheaper price) just to be sure, and it now works fine, no flickering in the dash lights or headlights.
I want to do a biopsy on the alternator to see if it is a diode or the regulator and replace the bad part. Then I will have a spare since the replacement one I got has over 200K miles on it.
Old 11-24-2013 | 03:45 PM
I am hoping it's just the battery terminals or whatever the other poster said. I'm hopeful as it wasn't doing it all the time. But I'm not a mechanical genius so what do I know?
Old 11-24-2013 | 04:15 PM
abran's Avatar
Try checking the connections at the alternator to make sure they are tight. Mine flickered and then I tightened the nuts on the back(specifically the smallest one) and the flicker went away.
Old 11-24-2013 | 05:30 PM
wrongway1's Avatar
Been trying to figure out the exact same issue for some time now. Mine does it occasional at best. New battery, alternator, and belt did nothing. Just ordered a new stalk & once in, I will let you know if it makes a difference.
Old 11-24-2013 | 08:28 PM
jimvw57's Avatar
I started out cleaning bat terminals and all the grounds I could find, any other connections and wire splices too, then went for the belt.
Bduncan26
10-26-2012 01:48 PM
jmccollister
09-23-2008 06:19 PM
rangeroverboi
01-31-2006 05:52 PM
Redmen69
12-18-2004 12:41 PM
Quick Reply: Flickering headlamps 97 Disco
