Fob questions.. (Don't have one)
Old 12-31-2015 | 06:41 PM
Coachgeo's Avatar
Found this in another thread. Something I will toy with
Originally Posted by ThorsDiscovery
The Fix:
..my key would still not operate the door lock from the outside.
I realized I had a rigged up way to lock and unlock; I took the jumper wire, still connected to pin 7 (Yellow and Pink) with the C225 connector still plugged into the evil green box, and touched it back and forth between the positive and negative terminals of the battery to lock and unlock five times.
Not only did it allow me to start the beast, but the Driver's side door lock works from the outside again!
Source: https://landroverforums.com/forum/di...05/#post275201
Now interestingly... one thing I noticed on mine; but previously ignored, is that there is a yellow wire (NO stripe) removed from the alarm plug which am sure is C225. I'll look if it goes in pin 7
Old 01-30-2016 | 02:48 PM
Coachgeo's Avatar
When looking at C225 how many yellow wires are there. I can't tell if the one not connected is yellow/pink or not.
Old 03-27-2016 | 05:35 PM
Coachgeo's Avatar
One disconnected is Yellow only and further reading says this is for Antenna alarm and is often disconnected by users with out issue.
calebbo
10-12-2011 09:54 PM
LoveDiscovery
10-08-2011 04:00 PM
guitarz32388
07-08-2008 02:27 PM
Quick Reply: Fob questions.. (Don't have one)
