Fog light relay, where is it?
I Checked the rave and pulled the relay. Fogs still worked. I pulled every relay above the passenger footwell and to the right of.
Fog lights will Not Go off
I'm trying to find the relay to rewire it so I can run fogs without heads on.
It's not like the range rover with relays at the under hood fusebox. I can see the wires from the switch turning left towards the drivers side fuse box. But can't find them there. Thought I can find a fuse. But rave points to the exact relay as to which it is. But it's anxious that's not it.
FINALLY FOUND A FUSE!!!
Im looking for a relay but I finally found a fuse that disconnects the Fogs... Its marked sidelights under the hood...
Something screwy is going on..
Any ideas?
Any ideas?
