Fog light relay, where is it?
Old Oct 24, 2010 | 05:24 PM
Spencerfitch's Avatar
Default Fog light relay, where is it?
I Checked the rave and pulled the relay. Fogs still worked. I pulled every relay above the passenger footwell and to the right of.
Fog lights will Not Go off
I'm trying to find the relay to rewire it so I can run fogs without heads on.
Old Oct 24, 2010 | 05:28 PM
Jull's Avatar
Fogs in the lower bumper or driving lights on the brushguard? On mine there is a relay beside the fuse box under the hood with the Hella logo on it.
Old Oct 24, 2010 | 05:39 PM
It's the factory fogs wiring i just have driving lights hooked up
Old Oct 24, 2010 | 07:00 PM
Look in the under hood panel, think it is there.
Old Oct 24, 2010 | 08:28 PM
It's not like the range rover with relays at the under hood fusebox. I can see the wires from the switch turning left towards the drivers side fuse box. But can't find them there. Thought I can find a fuse. But rave points to the exact relay as to which it is. But it's anxious that's not it.
Old Oct 25, 2010 | 08:18 PM
FINALLY FOUND A FUSE!!!
Im looking for a relay but I finally found a fuse that disconnects the Fogs... Its marked sidelights under the hood...
Something screwy is going on..
Any ideas?
Old Oct 27, 2010 | 10:05 AM
okdiscoguy's Avatar
The relay is in the drivers footwell behind the side trim.
bleizit
Jun 24, 2020 04:03 AM
RicketyTick
Jun 24, 2014 06:58 PM
abran
Oct 1, 2013 09:09 PM
s10lowrider1994
Oct 6, 2011 01:22 AM
dustinvonholten
Oct 10, 2010 09:40 AM
