Fog light wiring question
Old Sep 14, 2013 | 07:51 AM
wrongway1's Avatar
Default Fog light wiring question
Had a great day at the junk yard!! Got my Hannibal rack, extra fog light dash switch & the pigtails for the LR Safari 5000 lights I was looking for. My question is I need the wires that go from point "a" to point "b". Since I cant seem to find a wiring diagram for this purpose, can anyone tell me if this kit will this work? Oh, a diagram from the factory switch would be nice as there are (4) wires going into it. Thanks!
Old Sep 14, 2013 | 07:58 AM
CUpgt's Avatar
I just wired the pigtails. I'll have to see what the pin out is. I basically ran one heavy wire from the fuse box to under the steering column. Split to 3 lighter gauge wires and mounted three relays. All ghe lighting is LED with a low draw. Adjust wire ga accordingly. As for the switches I ran the back light power wire from 3 into one and tapped into the existing fog light harness. Pretty sure pin 4 is back light. Not sure the rest off the top of my head.
Old Sep 14, 2013 | 08:07 AM
CUpgt's Avatar
1 is power, 2 is back light, 3 is blank, 4 is output to relay, 5 is ground. Might want to double check 1 and 4
Old Sep 14, 2013 | 09:48 AM
wrongway1's Avatar
I noticed the switch pod has (3) different pin locations molded into it (i.e., fog light, cruise control & mystery plug with a blank) making it impossible to get (3) fog light switches into it like you have. Did you just shave them off the plugs?
Old Sep 14, 2013 | 02:35 PM
CUpgt's Avatar
Yeah. I bought the from brett and they had pig tails
Old Sep 14, 2013 | 10:09 PM
wrongway1's Avatar
Cool, thanks for your help!!
caymandrew
Apr 21, 2018 05:21 PM
abran
Oct 1, 2013 09:09 PM
ebg18t
Mar 1, 2012 07:21 PM
Spencerfitch
Sep 10, 2010 09:32 PM
behnam22
Oct 14, 2007 01:25 AM
