Found my coolant leak and then some
Old 03-01-2019, 09:32 AM
dialtonehero57's Avatar
Default Found my coolant leak and then some
Original thread in general tech talk
ive been working on resurecting this 1998 D1 we got for dirt cheap. I started with changing plugs and wires then ran into a coolant leak��. I fixed that then on a road test found a major overheat problem ��
Old 03-01-2019, 10:05 AM
logan_gibson's Avatar
Looks like someone got creative in trying to bypass the heater core.
How quickly was it overheating?
I'd probably go through the entire cooling system, if that heater-core was bypassed there may be more cooling issues.
Old 03-01-2019, 11:46 AM
ok well that’s interesting. I’ll trace out the lines and see what’s up. My thought is to start simple and do the thermostat. Then the water pump. It over heats with a decent warmup at idle then a good 5 mile romp down the road. The gauge was pegged.
Old 03-01-2019, 11:49 AM
Never wanna peg that gauge, it doesnt move unless its well over overheating.
Parts are cheap, replace them all at the same time so you dont have to keep draining and refilling.
Cost me a little over $100 to have my radiator re-cored and gone through, if you have a local shop it may be worth it to have that done.
A fresh and clean cooling system goes a long way.
Old 03-01-2019, 01:53 PM
Talking
what about the water pump? Would you do that at the same time to?
Old 03-01-2019, 02:01 PM
Yup.
New hoses, new thermostat and gasket, New water pump and fan clutch.
IF the throttle body heater hasnt been bypassed and ISNT leaking, id leave it be.
If possible, try running some water through the heater core and getting that back going as well if you want heat.
I hate draining these systems and bleeding them, so If I do work I try to do it all at one time.
Plus, hoses are like 5-10$ so its cheap and easy to do. Along with the water pump usually under $100.
Old 03-01-2019, 02:15 PM
Talking
Yup.
yeah sounds like all good advice. A little weekend end project🤣🤣🤣🤣. All tha to get it where I can get it smogged and registered and drivable. Then of course there’s an exhaust leak, O2 sensors and maybe a cat. #loveablelandrovers
Old 03-01-2019, 02:33 PM
WaltNYC's Avatar
If your coolant is new and/or clean, siphon it out of the top of the radiator with a 5/8" OD hose into a bucket or jug. Then return it when ready.
Of course if it is old, replace it.
Old 03-01-2019, 02:50 PM
Talking
it’s all new. There’s no drain petcock on the bottom of the radiator ?
Old 03-01-2019, 03:33 PM
whiskeynipple0088's Avatar
nope no petcock
- brilliant Land Rover
- get yourself a cheap hand pump from Harbor Freight
OverRover (03-01-2019)
Quick Reply: Found my coolant leak and then some
