Sponsored by: CARiD
Found my coolant leak
Old Feb 28, 2019 | 01:11 PM
dialtonehero57's Avatar
Talking Found my coolant leak
Found the source of my leak. Why build a hose like this? This is dumb and unreasonable. Now I have to find a brass fitting to match this plastic #pos and put more coolant in.
Old Feb 28, 2019 | 04:40 PM
Talking
Top is the problem.! Cheap plastic fitting. Bottom is my solution
Old Feb 28, 2019 | 04:43 PM
DavC's Avatar
Great job! On that car specifically there are so many spots for improvements like that.
Old Feb 28, 2019 | 07:02 PM
Talking
well thanks 👏. But after I got her warmed up and took her for a spin down the road it got WAY HOT 🥵. Barely made it home so I will try a thermostat after it’s cooled down. Aside from an exhaust leak it’s running pretty smooth. The idle is high but I figure once I get some things sorted out I can tune it up some more. The new plugs and wires made a big difference.
Old Feb 28, 2019 | 07:11 PM
OverRover's Avatar
Check the AC Condenser in front of the Radiator for any blockage.
In the pics you can see mud on the top of the engine and rad shroud, so maybe the condenser has mud blocking the fins as well.
Old Feb 28, 2019 | 07:50 PM
Talking
that would be the one in front of the radiator with the two fans in front? Yes? I should say that those fans never came in during the test run.
Old Feb 28, 2019 | 08:15 PM
OverRover's Avatar
Yes, the AC condenser is in front of the radiator with 2 electric fans.
If the fans didn't come on when the rig overheated can be a good thing, it means the coolant temp didn't reach over 212* F
So providing the fans work, this is how/when they function...
Old Mar 1, 2019 | 08:12 AM
WaltNYC's Avatar
dial, a couple of things...
1- post in the D1 section, you'll get more eyes on your posts
2 - put what model truck you have in your 'signature'. Look for the 'User CP' tab near the top of the page
3- Looks as though your heater core was bypassed. I'd check that your plumbing is correct. from the pix it is difficult to understand how it is set up.
this is from page 355 of the workshop manual pdf
Old Mar 1, 2019 | 09:16 AM
Talking
thx for the tips I’ll get more pics . It’s still overheats terribly. So I’ve got some work to do.
Saturnine
Aug 10, 2019 04:01 PM
Daytoman
Feb 10, 2019 11:53 AM
DiscoNickBK
Jan 19, 2019 12:07 PM
fleacz
Sep 18, 2018 01:21 PM
09dewaed
Dec 29, 2017 02:44 AM
