front axle shaft shims
Old 07-15-2016, 06:01 PM
AbnMike's Avatar
Default front axle shaft shims
I bit the bullet and replaced my lower swivel pin bearing today as well as the wheel bearings (both).
However when I went to put it all back together I couldn't get the circlip on the axle shaft - much less the 2 (TWO!) shims that came out with it (I kept the circlip and both shims in a baggie and only did the driver's side.
The circlip will go back, but not even one shim will go. I put a bolt in the end of the shaft and pulled it out as far as it will go.
So I know that some have 1 shim, some have 2 and even some have no shims, but since I pulled two out, I figured 2 should go back, right?
What did I do wrong? I'm pretty certain I got the bearing races back all the way in place which is the only thing I can think that would cause this to not seat right. Should I take it back apart and check those races?
Or did new bearings (the old ones seemed to be fine) push me out so I don't need the shims? I would think I'd need at least one.
Old 07-16-2016, 09:52 AM
AbnMike's Avatar
Nothing? No one has any suggestions? I know about pulling the shaft back out, did that, it just doesn't come back out far enough.
Old 07-20-2016, 10:31 PM
M1k3's Avatar
4wd High
Use a bolt off of the hub flange to pull the axle out far enough to put the cir clip back on. Should help
BCDisco2Lando
02-19-2014 10:21 PM
Rover Chris
12-05-2010 03:46 PM
mrossipir
10-09-2009 05:11 PM
treho54
10-19-2008 04:28 PM
Quick Reply: front axle shaft shims
