Front drive shaft rubbing on sway bar
All,
I recently finished up my 3" lift and had been driving my disco without issue until I put the castor corrected radius arms in over the long weekend. When I pulled the rig out of the garage, there was a timed thump that increased in frequency as I accelerated. I parked the vehicle to prevent any potential damage and checked the vehicle and noticed that the driveshaft appeared to be barely touching the sway bar.
I have found a few threads on this forum, some folks say it is normal and others say it is not. Can anyone confirm? I also saw reference to a sway bar drop kit from Toddco suspensions. Do folks have experience with this? it is only $35 so small change to prevent damage to my new Heavy Duty Double Cardon driveshaft.
Thanks in advance.
Thanks in advance.
I've been sans sway bars for two years. 23 hours back from Moab, 8 hrs to the Wilds, 10 hours to Kentucky, many 4 hour trips to Wisconsin and Badlands in Indiana. Not a big deal really. Everyone says "oh my God, I can't drive without sway bars!!!". If I recall correctly RRC's didn't even come with sway bars. If you have a 3" lift your springs are most likely HD and will help with the little extra body roll. Its really not a big deal. Even my wife can drive my truck without crying.
Speed racer
11-11-2009 09:44 AM
