Front right window regulator issue
Old Apr 5, 2011 | 07:50 PM
kamileon's Avatar
Default Front right window regulator issue
So my front right window hasnt worked since I bought the Rover. So over the weekend I figured I would tear it apart and get it working. My first step was to test the switch to make sure it was working, and it was. So I tore the door apart and began my trouble shooting. I thought that maybe the motor was bad so I pulled it and connected it to the front left door and it spun and sounded fine. At this point Im guessing it is a connection between the switch and motor. When I hit the switch I can hear a clicking sound coming from under the dash area around the glove box, I think thats were it is coming from. I checked the fuses and they are all good. So now Im down to start chasing sparks through everything to find the bad connection. So before I do that I thought I would jump on here and see if any of you have any suggestions on where to start.
I also found during my inspection that it seems to have the wrong window regulator in it. I compared it to the one in the front left and they were identical. Thinking that this may be a mistake on my part and it might be a universal thing I did some research. Turns out I was right, it had a left when it needs a right. So anybody got a spare right they are willing to trade for a left side regulator?
Old Apr 5, 2011 | 08:57 PM
The window lift ECU is behind the glove box.
Sounds like its your regulator though like you said.
I wonder if it is trying to go down when you want it to go up because its the wrong one?
Old Apr 5, 2011 | 09:35 PM
kamileon's Avatar
Well using a multimeter I determined there is no power going into the door. Plus when installed, before I tore it apart, the gear on the regulator wasn't even touching the gear on the motor.
Old Apr 5, 2011 | 09:39 PM
Remove the window lift ECU and open it up and check for cracks on the circuit board.
Re-solder as needed with a pencil solder.
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
jrkstore43
Dec 29, 2009 02:22 PM
