Front wheel "tilt"??
Old Oct 26, 2011 | 10:23 AM
DISCO1995's Avatar
Default Front wheel "tilt"??
I do not have pics to more accurately described my question, so I will attempt to do so other wise.....
95 Disco, 158K, working thru the high mileage recommendations...rotella is now in, brakes bleed, interior put back together, door handles adjusted, etc. etc. My question today....
If looking at the Disco from the front, straight on, what would be a likely cause of the right front wheel gently 'tilted in at top and out at bottom', if that makes sense??
Thanks in advance folks...
Old Oct 26, 2011 | 10:42 AM
calebbo's Avatar
Looking at the engine bay
Kind of like tilting your left hand to the right?
Old Oct 26, 2011 | 10:49 AM
DISCO1995's Avatar
Yeap. Don't believe it's alignment issue but could be I guess. Drives straight, etc. Responds to steering, etc. Haven't officially started that investigation yet but wanted to get some 'possibles'...
Old Oct 26, 2011 | 10:52 AM
calebbo's Avatar
Um.. no clue.. my "just stare and guess" answers would be:
Lug nuts: are they all tightened and torqued?
Hub assembly: is it warped?
Then I would go into "lets take a look mode" and find out
Old Oct 26, 2011 | 11:20 AM
ihscouts's Avatar
I would guess wheel bearings and then if that doesn't fix it (tighten or replace) swivels need attention. Getting any light wheel bounce whatsoever after running over road imperfections around 40mph or above?
Old Oct 26, 2011 | 11:21 AM
DISCO1995's Avatar
Not considerably noticeable bounce, maybe a little. Almost like the right front is set up like a NASCAR (certainly not that severe but that 'image'). I thought maybe RF shock/strut, then swivels??
Old Oct 26, 2011 | 11:29 AM
Long Haul's Avatar
My guess is either swivel bearing or wheel bearing. Jack that wheel up and see if you can move it in any direction.
philwarner
Feb 15, 2015 03:33 PM
mike031
Aug 13, 2009 10:12 AM
endneu913
Oct 16, 2007 10:19 PM
xb70valkarye
Appearance & Camping Set Ups
Aug 25, 2006 01:28 PM
herovc
Oct 11, 2005 08:39 AM
