Fuel Feed hose to Fuel Rail
Old Nov 6, 2013 | 05:00 PM
Grlica's Avatar
Default Fuel Feed hose to Fuel Rail
I'm near completion of an engine swap on a 98 Disco I with a 4.0. I am installing a 4.0 engine from a 97 Disco I. Everything matches up so far but the connection for the fuel feed hose to the fuel rail. The connectors are different. Not sure what to do. Possibly take the whole rail off the removed 98 engine and put it on the 97 engine? Not sure if possible, they look a little different.
The 97 engine, which I am installing, has about 2 inches of the feed hose still on the rail w/ the connector as they simply cut the hose. Can I cut my existing hose and connect them some how?
Any advice much appreciated.
Old Nov 6, 2013 | 09:39 PM
XCELLER8's Avatar
in theory...as long as you can splice the connection and make it seal,you should be ok....
My buddy's 97 IS slightly different than my 98 ...as far as the fuel rail and fuel pressure regulator..but they look alike enough to work either way
locknload7
Oct 8, 2013 06:47 PM
bbeismann
Apr 1, 2013 05:13 PM
JumPeR04
Apr 7, 2011 09:52 PM
Derrick
Nov 23, 2007 07:58 AM
Derrick
Freelander
Nov 22, 2007 02:15 PM
