Fuel Injector problems?
Old Jun 20, 2012 | 08:59 PM
narich88's Avatar
Thumbs up Fuel Injector problems?
1996 Land Rover Discovery
Truck starts up, idle drops to normal (around 750-800rpm) then cuts out and all power to the engine stops. Truck restarts, idle drops to normal, then drops much lower (below 500rpm) then holds. Sometimes if I rev the engine it will catch it, and the truck will start, then resume regular idle. If it has to restart a few times, I have continuous problems.
I'd like to know if this is a fuel injector gone bad or maybe multiple? I bought the truck with the No.7 injector staying open and flooding the engine if the car isn't completely turned off after being driven.
Can anybody give me some advice? My first post and Land Rover. Thanks for the help.
Old Jun 20, 2012 | 09:19 PM
The injector will leak even with the key out of the ignition because there is pressure in the fuel line.
You need to fix that before anything else.
Old Jun 21, 2012 | 10:50 AM
sean152's Avatar
i have a very similar issue with my 98 series 1, it starts fine and idols a little rough butt still fine. and assoon as i try to move off or even rev the engine it dies out and stalls. could this be the same issue? i was thinking an issue with the fuel system butt im just not sure
Old Jun 21, 2012 | 11:10 AM
Discolife's Avatar
Sounds like a tps issue
landroverfan001
Sep 2, 2013 09:10 AM
Willem Swan
Jun 27, 2012 10:44 AM
gmca01
Freelander
Jun 7, 2012 02:03 PM
discoper
Mar 20, 2008 09:22 AM
DeepBlueWater
Oct 15, 2007 07:38 PM
