fuel presure regulator vacuum pipe
Old Aug 31, 2013 | 06:02 AM
jocko1963's Avatar
Default fuel presure regulator vacuum pipe
hi can anyone help me please i am replacing the vacuum pipes on my v8 3.9 disco because the where all perished but i have found that the pipe from the fuel pres regulator is missing. so i need to replace it but where does the other end go.
Old Aug 31, 2013 | 07:20 AM
Scope's Avatar
I know on my 4.0 it is about four inches long and goes from the fuel pressure regulator
to an small nipple on the back side of the plenum.
Old Aug 31, 2013 | 01:04 PM
mmaesner's Avatar
on my 95 3.9 it is abouit 8" long and goes to a stem under the IACV that points back at the firewall
Old Sep 1, 2013 | 06:08 AM
jocko1963's Avatar
thanks lads been looking in manuals and on other engines but all say and look different. so im going with confidence and gonna sort it. thanks again
Old Sep 1, 2013 | 07:23 AM
Here's a pix of a 97, which uses a source of manifold vacuum close to the regulator. Needs vacuum from somewhere, even if a plastic T is needed. Important to note that the engine vacuum and cruise control vac are two different sources and should not be mingled.
franz
Mar 24, 2011 03:46 PM
griffon
Dec 24, 2009 07:51 AM
sforb
Sep 3, 2009 05:11 PM
cold_surfer
Aug 15, 2009 09:59 AM
Disco C
Oct 23, 2008 06:39 PM
