Fuel pump for a 1996 Disco 2
Old Jan 1, 2011 | 06:44 PM
Fugue's Avatar
6th Gear
I do realize that a high performance pump cannot overcome a regulator or fuel lines BUT there are some vehicles that come with inadequate pumps that cannot provide the required pressure.
Someone claiming to know rovers said this was an issue with D1s. I was just searching for clarification.
Old Jan 1, 2011 | 08:43 PM
kenk's Avatar
Originally Posted by Fugue
Ignore me?
I wasn't telling him to go find a high-po fuel pump. I was asking if that was a worthwhile upgrade.
Apparently it isn't. Good to know.
I think he was saying ignore the person telling you to put a hi-po pump in, not ignore you.
Old Jan 2, 2011 | 06:22 PM
Danny Lee 97 Disco's Avatar
the only fuel pump you should consider putting in a 96 DI is a ProLine from Rovers North for 100 bucks. It i an exact drop-in replacement for the LR original. Mine is working fine and has been for three years.
Old Jan 2, 2011 | 06:33 PM
antichrist's Avatar
For up to VIN VA546029, if it's just the fuel pump, you can use a Delco EP241 or equivalent. Around $50.
Old Jan 3, 2011 | 08:50 AM
Draayer's Avatar
Default Where is the pump located?
So where is the pump located? is it in the tank? Did Land Rover make them easy to get to or is it a major project?
Thanks,
Old Jan 3, 2011 | 08:58 AM
antichrist's Avatar
It's in the tank, as is common on EFI engines.
It's not too hard to get to.
You have to remove the pump assembly and take out the pump. There's a tech on discoweb.org for replacing the pump.
http://www.discoweb.org/forums/showthread.php?t=14451 (you have to sign in to see the attached photos)
I also found this, which is actually information I'd been looking for:
http://www.discoweb.org/forums/showthread.php?t=43692
E3240 (listed as for the 3.9):
- Gallons per hour: 40
- PSI shut off: 65-95
- Type: Rollervane
- Volts: 12
E3270 (listed as for the 4.0):
- Gallons per hour: 50-60
- PSI shut off: 80-90
- Type Rollervane
- Volts 12
The cases and wiring are the same for both.
Old Jan 3, 2011 | 09:27 AM
antichrist's Avatar
For people with non-AEL engines it looks like the Delco EP241 has come down in price.
$65 with free shipping from Amazon, worth it to have a spare IMO.
http://www.amazon.com/ACDelco-EP241-.../dp/B000C9OSAM
Old Jan 4, 2011 | 11:59 AM
On mine, the top of the fuel pump assembly had a nasty crack develop in the plastic. A new fuel pump assembly was the only option. If someone wants just the pump, I have the old one from mine sitting on the shelf.
I prefer the complete new assembly over just replacing the actual pump.
Old Jan 4, 2011 | 01:48 PM
antichrist's Avatar
That's fine if a person wants to do that, but people need to know it's not really necessary.
Old Jan 5, 2011 | 11:08 AM
Chris-bob's Avatar
Ignore me?
Sorry. I meant to say ignore the suggestion to get a performance pump, not to ignore you.
Travelor
Sep 24, 2015 06:11 PM
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
kenton311
Aug 17, 2008 04:03 PM
AndrewPilkinton
Dec 5, 2007 06:07 PM
